sdcbowler
- Joined
- Jun 4, 2015
- Messages
- 184
- Reaction score
- 43
Hi Members,..
Came up against a new issue when working on my exhaust system....'70 Challenger, 426 Wedge. Manifold casting numbers are Left: 2951865 / Right: 2899879. Car was originally equiped with a 383/2 barrel. Exhaust pipes are 2.25 dia purchased from an aftermarket supplier. Started on the driver side first, and completed with no issues. Then went to the passenger side and found the flange on the exhaust manifold was smaller than the flange on the exhause pipe. Although this did not make sense to me, I had to come ask the forum if anyone else had come across this issue ever before.
My engine rebuild gasket set came with the exhaust manifold to exhaust pipe gaskets. I placed the gasket on the exhaust pipe and it clearly fits. I then held the gasket againt the exhaust manifold mounting flange, and you can clearly see that they do not match...... You can see in the pics. The first and second pics are of the exhaust pipe and gasket sitting on top. The third pic is me holding the gasket against the exhaust manifold flange.
Not sure where to go from here. Any advice or reasoning would be greatly appreciated,
