Do i want OEM exhaust manifolds?
Mopar Nut
toolmanmike
Super Moderator
Staff member
Iowa
Thanks- that's what I'll be doing,giving it more time to consider. But... I may post a WTB for the correct exhaust manifolds.
That's exactly what you should do. The #549 and #553 manifolds fit the A body 340 cars as well. There is often a set or two floating around FABO at any given time. It's interesting the price increase in those things in the last year or two. For a long time, a nice set would sell for $500. Now they are $7-800 with the really nice pairs commanding upwards of a thousand.
don selleck
michigan usa
I'm will be putting my six pack on my AAR, was going back and forth on the header/ manifold, car will look stock pretty much anyways, so going with the manifold. around a 500hp stroker into a long head pipe into power stick chambered exhaust pipe, similar to the innards of the side pipes on the older vette's. Then found a place that sells AAR stainless exhaust tips that are not baffled in the trumpet outlet. probably will be loud as hell, but I'm good with that. :lol:
Tom's EK2
Harlan, Indiana
I'm will be putting my six pack on my AAR, was going back and forth on the header/ manifold, car will look stock pretty much anyways, so going with the manifold. around a 500hp stroker into a long head pipe into power stick chambered exhaust pipe, similar to the innards of the side pipes on the older vette's. Then found a place that sells AAR stainless exhaust tips that are not baffled in the trumpet outlet. probably will be loud as hell, but I'm good with that. :lol: View attachment 133777View attachment 133778
Sounds Perfect!
Kinda thinking I should have stayed with the manifolds myself. I used the 440 carbs on my 6 barrel intake. My 340 is close to 440. Runs excellent.
The driver side If I recall right was used up through 72 on A bodies.The passenger side was 68-70 A and E bodies.
toolmanmike
Super Moderator
Staff member
Iowa
