- Joined
- Oct 17, 2011
- Messages
- 7,172
- Reaction score
- 1,949
Never, ever, ever, ever assume anything especially when automotive related. When you buy an unknown, before you start to change or adjust things, you need to verify and know what exactly you are working with. Some red flags are "looks to be 10.2:1 compression " Is the what has been measured , shown with a receipt or a guess ? Aluminum heads with a stock spread bore intake, with a square based carb& base adapter.
original, stock ignition. Should have been at least a higher performance ignition to fire the plugs an a high compression engine and a performance curve. A matched intake and carb setup for the aluminum performance heads. You didn't say what type of exhaust. A good quality set of headers, exhaust system. The engine package has to work together. Not unlike cooking a recipe without all of the proper ingredients. Looks like a rebuilt long block completed with stock parts. Not even close to a proper performance build. The guy builds race cars ? Who does his tuning. Who assembled this motor him? How do you know what parts were actually used ? His word? Receipts ? Photos during the build ? Like said earlier, need to verify the cam specs, preferably with the paperwork that came with the cam. Degree the cam, this will also allow you to verify that a new timing gear/chain were installed. You can never ,ever, assume/trust what you haven't seen for your self. Verify compression. The more information that you have, the better the decisions that you will make when choosing other parts to enhance performance of your package. Looks to be only half way done. I would put it on a stand and do a teardown to see what I have and go from there. JMO Get a degree wheel, accurate torque wrench, dial indicator, vacuum gauge, good quality basic tool wrench/socket set. A clean place to work where you can cover and store your work. Patience, a service manual and a good friend to help and motivate you. Hopefully with some experience with automotive tools and prior repair experience.
