#8 cylinder always colder and dead cylinders!
Lanman70
Omaha NE
Fighting this issue for quite awhile. Bought car 2 years ago, 1970 Challenger SE, originally 383 2bbl single exhaust, at some point before I purchased converted to 4bbl, unknown cam and headers. Did all the basics over and over, plug wires, plugs(twice), cap, rotor, coil, ballast resistor, voltage regulator, new carb. Randomly the car will run great and then next time I start it runs bad. #8 is always colder and sometimes dead cold. I am using a temp gun on the header pipe. The other day #1 was dead cold after running 20 mins. I have not changed the distributor yet but I have one to try. Any thoughts on why it would randomly have dead cylinders? Plugs don't show signs of fouling. I have not changed points. Thank you.
cuda joe
nj
no heat = misfiring plugs should be wet with gas the reason for the misfire ? could be bad plug 'bad wire ;'bad dist cap ;even could be to lean fuel mixture ;or vacuum leak.. i would start with plugs wires new dist cap . i diched the points went to pertronics ignition world of difference
I;ll never go back
Bret Schneider
Probably noteworthy that the two problem cylinders, #1 and #8, are adjacent in the firing order and on opposite sides of the engine. Intermittent issues that move from cylinder to cylinder almost have to be ignition related.
There aren't many things that could go wrong in a points ignition that would cause a problem like you're describing.
Could there be a problem with the distributor cam? Maybe the #1 and/or #8 lobes flattening out a little?
I'd pop in the other distributor and see what happens.
Lanman70
Omaha NE
Swapping the distributor is my next move. Fired it up and it ran good yesterday, with #8 still running 100 degrees cooler than the others. I think the vacuum advance in the distributor has issues as well. Thanks.
Lanman70
Omaha NE
How would you fix a lean condition if that is the problem? Currently running a new Edelbrock 1906 AVS2.
cuda joe
nj
a lean condition would probably be a vacuum leak bret has a good idea with the dist cam check to make sure all the lobes on the dist cam open up the points the same amount
cuda joe
nj
oh yea the easy way to do that is to use a dwell meter google how to do the tests it needs to be pretty steady at idle and blipping the throttle and check dist shaft for play
