scottylack
- Joined
- Sep 11, 2009
- Messages
- 88
- Reaction score
- 8
any thoughts on this?
Just Dashes is an old, well known source.
Just Dashes Production Center: Instructions: 1970-’74 Mopar E-Body Dash Pad Removal and Replacement
http://www.justdashes.com/
It's not gas Pros Dash ProsIf the “ gas pros” are out of El Paso, then they are the same company that was called ultimate rides. I’ve never had dealings with them but most of the ones they sold in the past are hit or miss. Sometimes they don’t fit well. They used plastic cores for awhile but that did not work out. They sold the dash under several different names. Good luck with the pad. Maybe they got better. The company called abc Moparts has sold a, b and c body pads for awhile and I think most were pleased with them. They just started an e body pad that might be ok. It’s a 71-74 pad though. It’s 795 plus a core. I think they took the new pad to the Nats this year. Maybe someone here saw it. I know you really can’t tell on a repop pad until you bolt it all together and install it. Then you’ll know if it fits. I’ve had several of the just dashes pads in my shop and they all look and fit perfect. I’ve never heard of any complaints on one of their pads. So, the bottom line is this. The Just Dashes pad is $500 more to get one that is going to be correct. When you look at the overall price of a restoration, $500 is pocket change. These cars are just expensive. No way out of that. Save some heartache and send it to Just Dashes and be done with it.
Sorry I didn't proofread before I sent Dash Pros is the name of the company and it is out at El Paso I'll let everybody know about the fit and finishIt's not gas Pros Dash Pros
