Beware unisteer
onedonbob
Nothing but problems . In the words of there tech guy , the directions are wrong . First of all , don't try to mount the helm joint brace to the frame rail. After I tried , I was told it's not needed . Then after every possible combination of u-joint phasing. It still
binded. (Badly ! ) . The angle of the shafts of the rack is too much. It actually points towards the radiator. Maybe there's someone out there that has successfully installed one but , on my 74 It would not work ! Don't get me wrong ,I talked to there tech department many times. No one could give me a good answer as to way it was not working. Eventually they did give me a full refund. Now I'm stuck with a cut off steering shaft . I'm going to try a bergensen box .
