Clutch Pedal Help
Clinks68
North Carolina
Hi everyone, 70 Challenger R/T 440 six pack, 4 speed, I push my clutch all the way down and when i release it comes back up about 3/4 of the way and stops, if i barely pull on it, it comes up all the way. The arm that goes through the firewall where it attaches to the clutch pedal with the clip on it seems to be sloppy. Is it missing a bushing of some sort/ metal or plastic?
Daves69
ChiWest
The clutch peddle rod has oblong holes as designed.
You need to determine which clutch setup you have installed.
A diaphragm setup typically has the stock OC spring removed and peddle return tends to be lower than a 3-finger B&B setup.
The OC (over center) spring works in both directions on a 3-finger setup. It assists in peddle effort to release the disc and it also returns the peddle to top when adjusted properly.
Clinks68
North Carolina
Brewer's Performance has both reconditioned and reproduction pedal kits.
Brewer's Performance - Mopar A833 4-Speed Transmission and Component Specialists
Thanks Dave, I put it on my lift and found an adjustment problem in the linkage. I adjusted it and now seems fine.
