Pinion angels
hpjunke
Ok need a quick recap i measured my driveline angels today and got these measurements .. Now i’m pretty sure i need a 2 degree shim in the rear to make my operating angles pretty good .. Is this correct or iam i missing something here .. ?
Thanks guys!
4 degree comes to mind is what is ideal maybe not in you case. not sure let me find something. not sure of what your doing.
hpjunke
Looking to eliminate vibration….
Don't know why how or what happened. Remove drive shaft and put back on and had a vibration. Turned 180 and vibration was gone. Not sure if this is you case or did you lower or raise?
hpjunke
Angles are off it has a 6.1 hemi 545rfe and it needs the pinion set agian
Now we get more information... Basically a truck/R.V. transmission.
The pinion and tailshaft angle need to be compatible.
Look in the FSM for 70-74 Challenger Chassis Manual in th Propeller Shaft and Universal Joint section, 16
