Howdy folks. I have a 71 cuda clone, 340, 4 speed. Last night I pulled into a convenience store on the way home. When I went to start the car to leave, the starter motor would not disengage. The car started, but the starter motor continued to crank. I turned the car off, removed the key from the ignition, and the starter was still cranking. The clutch pedal was not depressed. The only way I could get it to stop cranking over was to disconnect the neg battery cable. Starter and ignition system is essentially stock. No previous symptoms like this, car has been running fine for a couple years. Starter and ignition switch were replaced 3 or 4 years ago due to a non-start issue.
Car's in the garage, battery is charging. I'll look at it later with a voltmeter. Starter? Relay? Ignition switch? Any time-saving suggestions would be appreciated.
Thanks.
Thanks.
