marksmopars
- Joined
- Dec 2, 2011
- Messages
- 87
- Reaction score
- 80
340’s that came with forged rotating assemblies were internally balanced and torque should be neutral balanced as well. Later 340’s and then 360’s were externally balanced. From the pics of the 340 unit it looks like some weight might be needed for neutral balance, depends on what year the 340 was that the unit is from. Later 340’s used cast as did 360’s which is why different balance specs.
I believe you indicated your engine is internally balanced at this point, this does point at the tc balance. Good luck
