Welcome wagon
1970CUDAAAR
Gatineau Qc
I'm new (past 4 months) to the forum. I own a 1970 CUDA with a 440 HP - with a Holley Sniper EFI -with a HEI distributor.
I'm getting all kinds of number on how to set the timins - is the following OK for a street car with is Moapar extreme energy cam (Lift = .477 INT .480 exh - Duration .268 Int .280 Exp):
Initial timing on balancer 8 degree
Timing appearing in the Holley manual = Idle 18-34 - Cruise 32-44 - WOT 28-40 = which one is good for me
AFR - Idle 14.0 - Cruise 14.5 - WOT 12.5 (suggested by Holley)
Thanks!
moparlee
Mid Michigan
Welcome to the site from Michigan!
If you post this up in the Engine Issues forum you will probably get more responses.
fasjac
Arkansas
Welcome to the site from Arkansas!
As Lee said, you’ll get some help for sure.
Initial timing sounds a bit high to me but, don’t know with efi. I do know voltage and grounds better be as good as it gets with the set up.
My buddy just removed the same system and going back to carb. They just couldn’t get to perform right consistently. His job keeps him away from the car sometimes 6 months at a time. ?? Lots of guys love em though. Good luck to you and glad you joined up.
Mopar Nut
1970CUDAAAR
Gatineau Qc
Here are some photos. When you store a car for the winter and remove one cable from the battery does that kill the memory of the EFI monitor. In other words is it possible that some data need to be reloaded as a result of a prolongue disconnection of the battery? Also in the Holley manual it indicates that hte setting for Baic Sparks is Idle 18-34 - Cruise 32-44 - WOT 28-40. How do I determine which no. is the right one for my application: 440 Mopar - Street Cam - HEI Ingntion, Thanks!
1970CUDAAAR
Gatineau Qc
I presently have a aftermarket HEI distributor with a coil. My understanding you cannot use the EFI Monitor to set the timing. It looks that to do so I need an Hyperspark distributor at a cost of over $ 450. Is this realy true??? What can I do with my aftermarket HEI wit a coil. Thanks!
