Fuel pump pushrod fell into block
7DCUDA383A
60 Miles West of STL
This is exactly what I was thinking of trying first if it happened on mine using a rare earth magnet. You can’t start it without the fuel pump pushrod anyway unless you use an electric fuel pump.
I have another pushrod , thats why I wanted to drive up on to ramps instead of jacking the car up .
Hemifiedbird
Red Deer, Alberta Canada
I already did all that , since I never did this before I tried to put the rod back in the big hole , had no idea I was supposed to use the plug hole , thats just me not doimg enough studying , it fell down into the crank or oil pan I think , not sure .
So you took the rod out the plug that it is suppose to come out of and then decide to put it back in the big hole? Why!!!!!.
7DCUDA383A
Never changed a fuel pump on an old car before , this is all new to me and was trying things for myself , simply messed up and now I know , I was going to change the oil pan out anyways so hopefully its in there .
7DCUDA383A
UPDATE , yes the push rod was in the oil pan , also I just installed the Moroso deep transmission pan with the thick blue gasket , hope this works because it kept leaking on the front passenger side , and also installing a molded windage tray with a 402 stamped pan with no sealant except at the corners , hopefully no leaks .
fasjac
I really haven’t heard of that happening before. But, you know what to do to remove it.
cuda joe
nj
it;s good to hear you got it the warm weather is here happy motoring
fasjac
Yes , rookie mistake , I wanted to change the oil pan anyways , the 7 qt hung down too far in my opinion so went back to a 5 qt .
Hey, no harm no foul. We’ve all had them.
Great time to get that pan off!👍🏻
