That looks like it is wired as it should be. Bulkhead wires connected together when starting and running. Stock coil and distributor? It' seem like it is a bad connection somewhere.
Your are going to have to go through the process of elimination.
As I suggested unplug the connector and wire up switches to the connector. As I said you can use any sw for test purpose. House light sw. It could be the connector or connectors is not making a good connection all the time.
