Righty Tighty
I just bought my '74 Barracuda, and it had been sitting for at least a decade prior to me bringing it home. I've gone through everything and freshened fluids, changed filters, etc., before starting it for the first time.
Well, all that was done and now it's time to start it. Fresh battery, new starter relay, new ignition mod, new cables, and I've ensured a good ground. The old, full size starter is still in the car. It's cranking VERY slowly, and eventually stops cranking. Depending on the day, I usually have around 12.5-13.5V at the battery, 5V at the coil while connected, 12V on the coil wire when disconnected.
I tried the screwdriver trick to check for spark, but I can't see a spark either from the plug wires or the coil wire. I'm not sure I'm doing the test right, so I got an actual plug tester that lights up upon cranking. Hopefully that will give better results.
I bought a new mini starter from a '91 Dakota, hopefully that will help, but I suspect there may be more than one problem I'm dealing with. Can anyone help with some troubleshooting tips?
