flamesoldier
No blue wire anywhere there is a 2 wire magnetic pickup distributor that plugs directly into msd 2 wire output
Can it just be that msd box is shot? Because everything else is fine up the the box i even did the jumper wite for the green and blue wores from box and it beeps so the troubleshooting on msd site says if that passes the ignition system up to that point is fineThat's what I was wondering. All I can do is keep shotguning you answers if I don't have the diagram. many of parts have gone by the way because of bad connection.
The coil can be check with a ohm meter.
That what it appears i dont have power to the coilYou said : "The msd box has 12v but its not sending spark to coil so the box is shot it appears"
The msd box doesn't send spark to the coil. It sends 12v to the coil. Then it turns it off and the field collapses, the voltage goes through the secondary winding, that's where the spark comes from that goes to the rotor. I there is power to the msd and there is power from the msd to coil that part is good .
Leave everything connected as it is or take the wire off positive before putting jumperRun a jumper from the battery to the plus side of the coil and bridge the relay to see if it will start.
I will draw a picture to show how its wired.The original wiring of the car is. you really have to look at the colors, could be a little discolored. The dark blue ing 1 is for start only. It only has power when in the start position, it puts full voltage to the coil for starting propose. The brown wire is what feeds the coil when running. When in the run position it is reduced through the resistor. I know you said it has no resistor as per msd instructions. I think you need a jumper to tie them together. The run and start Dark blue and Brown. check instructions. not sure of color of wire you are working with.
The brown wire over time will melt the insulation in areas from use or abuse.
Yes that is correct, i have both blue and brown ignition 1 and ign2 inline for red “connects to a switched 12Is this what you have for instructions?
