starter
open headers
massachusets
i have a 73 challenger.last week drove up north. I was in bad traffic . shut AC off. temp climbing. put neutral the starter engaged. got to house finally. when parking starter came on in neutral then in reverse.i shut it off. all wiring is new . selaniod is new.starter got fried. what would cause this.
70chall440
Western Washington
My first guess would be some loose wiring that is making contact when it shouldn't. I would check the wires down on the starter first and then follow them and make sure everything is clean and tight. Don't know what starter you are using, but if you are using a mini starter and it has the raised connections it might be making contact with something (exhaust?). Also check that the starter is tight.
If all of the wiring is right/correct then something else is going on perhaps with the switch or the switch wiring. Trace it and make sure everything is good.
tonysrt
Could be ignition switch sticking. Not returning to run position.
